tannercruse10
I have a 2002 Dodge Ram 1500 with the 5.9 in it and it had a code for cylinder 7 misfire so I changed the plugs and wires and the code went away but then it started backfiring so I figured I had the wires crossed so I double checked and it was right so then I checked the distributor and spun it to see if I could get the timing right with that and no change so I changed the crankshaft position sensor and still no change.. any suggestions of what else could be wrong?
