BDS 3" lift
trx680
2006 2500HD Mega Cab 4x4
Inquired a local lift shop about lifting my 06 2500 Mega cab 4x4 gas.
They recommend a BDS 3" lift with Fox shocks for $1400+ install ..... yes I just want a few inches of lift. His words this BDS is top on the line. Though he could do a leveling kit for much less.
So what do you guys think of the BDS?
Stangshcky12
Oshkosh, WI
5.9 Cummins
Becareful as there are two different BDS 3" kits
One is spacers, one is a full lift kit with the full lift kit being a pretty good kit.
I wouldn't call BDS top of the line but they are a high quality kit
This is another 3" kit that you may want to consider. It isnt a full lift like the $1400 BDS kit but it has everything you really need and the ride will probably be better.
Dodge Ram Leveling Kit for 1994-2012 2500/3500 trucks
NWRQC
Another option would be going with Thuren. Thuren Fabrication-products
I really like how they ride.
I don't know much about the BDS kit but it comes with everything that you would need and then some.
Like Stangshcky12 said, all you really need is the springs, end links and shocks for 3" and below. You could add UCA/LCA to recenter the axle (by about 1/4") but it's not necessary.
