Bearings or the CV?
Discussion in 'Tech Info' started by AustinB, Nov 9, 2016.
  1. AustinB
    AustinB Banned
    3,944
    1,963
    Sep 8, 2015
    San Diego, Left Coast
    Ram Year:
    Engine:
    2015, 1500, 4x4, 40k miles
    Slight clicking noise around 1-5 mph, squeak with wheel spin from 5-10mpg, and a faint vibration noise at higher speeds (almost sounds like using brakes with no pads).
  2. sbarron
    sbarron Senior Member
    2,727
    1,538
    Feb 28, 2015
    Wasilla, Alaska
    Ram Year:
    Engine:
    both? lol
    one good thing about changing the CV, you're already there to change the bearing.
    AustinB likes this.
  3. AustinB
    AustinB Banned
    3,944
    1,963
    Sep 8, 2015
    Ram Year:
    Engine:
    Getting mixed answers.. didn't really pay attention when I had it apart a year ago..
    Are these the sealed hubs or can you just replace the bearings?
    Done with this ifs stuff.
  4. DannyMK2
    DannyMK2 Senior Member
    29
    1,723
    468
    Mar 25, 2013
    Long Island, NY
    Ram Year:
    2015 Power Wagon
    Engine:
    the hubs are sealed. clicking noise i would probably suspect a cv joint. check the wheel bearings for play to be sure, its easy enough to do.
  5. AustinB
    AustinB Banned
    3,944
    1,963
    Sep 8, 2015
    Ram Year:
    Engine:
    Actually, after getting the truck in the air... the problem is in my right rear.
    The wheel wobble under acceleration, including the rotor. The wheel was removed and put on a balancer, it's not bent. I don't have any vibrations or noises from braking so I guess that would cancel out the rotor..
    My guess is a bent axle??!
  6. kg93
    kg93 Senior Member
    24
    1,590
    445
    Nov 7, 2014
    NJ
    Ram Year:
    Engine:
    did you at least check the rotor? Id think that a bent axle would cause a little bit more vibration then a slightly warped rotor
  7. AustinB
    AustinB Banned
    3,944
    1,963
    Sep 8, 2015
    Ram Year:
    Engine:
    No, didn't check it.
    I will before I buy an axle though, just for reassurance.
  8. pickupman66
    pickupman66 Senior Member
    692
    140
    Dec 30, 2013
    Tennessee
    Ram Year:
    2009
    Engine:
    my front bearings made a clicking noise when I spun the wheel in the air.
  9. AustinB
    AustinB Banned
    3,944
    1,963
    Sep 8, 2015
    Ram Year:
    Engine:
    Its definitely not the wheel or the rotor.
    And the bearing is definitely shot...but it's just so hard for me to wrap my head around it being a bent axle. How in the fk would the axle bend? I haven't jumped or hit anything.
    Question: before I tear into it.. could a bad bearing cause the axle to move like that?
    Dealership will warranty the axle, but not the bearing. I already have the new bearing, just want a second opinion.. plus I'm trying to avoid rental car charges for a week+.
    https://youtu.be/EViVeV90n1A
  10. Rzrman328
    Rzrman328 Senior Member
    34
    5,769
    2,865
    Aug 25, 2014
    The treeline
    Ram Year:
    Engine:
    Looks like an excessive amount of play to be just the bearing. but I also don't think it's a bent axle....hmmm
Share This Page
