Woke up bright an early to install the OEM mudflaps I’d bought and didn’t have time to install yesterday.
I should’ve bought Weathertechs.
First, the instructions are wrong. No, really. MOPAR factory OEM installation instructions are wrong. Part is right for my 2018, but where it says to trim away plastic from the front flap? Don’t do it. Just. Don’t. Do it. I wound up reattaching the piece with pop rivets and cutting a simple notch for the left hand side mudflap after some trial and error. Yeah, looks like a real kludge, but I’ll spray some undercoating on the rubber/plastic and never look at it again (it’s on the passenger side).
Rears? Should’ve taken minutes, took about 45. Screws don’t line up. No cutting required, but a third hand, a pick/nail or very thin screwdriver helps to locate the metal clip nuts. If you don’t have a right-hand drill adapter (I have one, Dewalt), it’s going to be nearly impossible to drill the remaining screw hole without taking the tire off.
Of the parts provided, there was a handful I didn't wind up needing/using.
#2 - changed cabin air filter. Will drive around later and see how much less the cabin smells of stale coffee and cigars (it’s faint, very, very faint, nothing Febreze won’t cover, but then I go around smelling/inhaling febreze on my commutes, but hey, I saved about 15,000 buying a ten month old truck, and my dog will stank that thing up in no time). If weather holds, will use a steam carpet cleaner we own on all the cushions.
#3 - Deezee tailgate lift. Step by step instructions are flawless. Used a centerpunch to mark the nut, turned ten times. Greased fittings w/ green grease. Amazing hack.
#4 - Added a bottle of water wetter to the radiator tank. I use the stuff in my HMMWV and have noticed about a five degree drop in temps. Subjective as hell, but why not. Stops bubbling, breaks up surface tension allowing better contact between water and hoses/metal allowing for better heat transfer.
Weathertech mats ordered, not delivered to my friend’s shop even though there’s a signature release. Won’t get ‘em until Wednesday [insert frownie face here].
Westin stainless steel nerf bars on the way.
Meanwhile, looking at the underhood lamp, bed lamps, transfer case plate, then my allowance is spent until June 2019.
