So... LT315/70R17 113/110S C or 35x12.5R17 Both BFG KO2's
Any advice on which to choose for a 1500 4x4, used as a daily driver as well as off road (nothing harsh sand/mud trails in Florida). They will be going on ATX mojave 2's (9 inch wide) rims. Occasionally towing a 5k boat.
I know both will be infinitely better than the current stock wranglers. The 315's are about 60$ cheaper each. Truck is will be leveled with bilsiteins at 2.1 or most likely 2.8 they are going on the same time as the tires.
I think they both measure out to 34.5 diameter, any reason to go with the 35's vs the 315's in this situation? load rating on 315's is 2535lbs vs 35's at 3195lbs thats the only real difference I can see, but most of you have way more experience with these tires than me!
Thanks!
Thanks!
