Bigger then 6inch suspension
Dakota Tucker
Oklahoma City
2003 Dodge Ram
Ok here’s my deal I bought a 2003 Dodge Ram 1500 did a 4.7 to 5.7 swap with a cam upgrade valve springs pushrods the whole thing I also added a set of 20 x 12.5 wheel wrapped in 35 the truck currently has a 6 inch lift on it and my tired barley have clearance do they make a bigger then 6 inch lift bc that’s all I can seem to find
yillbs
They do, but it' not a good idea. The trucks do not do well in windy situations. Amy5hing higher than 6 inches will significantly cause issues on the freeway with mpg. If it' your daily driver, stick with the 6 inch lift. 35 inch tires should have more than enough clearance. Hat tires are you running
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
:welcome: to the forum . Post those pics.
