Bighorn with 8.4 and no media hub?
et todd
Was checking out the wanted section and a fellow member has this and wants to add usb.i've never seen a 8.4 factory installed without a media hub.I told him to post here for some help. check out the wanted section for pics of his setup.does anyone have information on this setup?
Kapt
3L
It's not in the center console?
E
et todd
Nope just a 12 volt outlet.
kwend
Twin Cities
2017 Big Horn
Hi all, sorry this was me. I just bought the truck about 3 weeks ago with 9K miles on it. Window sticker attached shows this came with a center console from the factory and USB hub.
Its weird. There is no Aux input, no USB charge, and no USB port in the center console. Only a cig power plug. I pulled the rear vents off of the console but did not see the wiring installed for the hub. The Uconnect 8.4 head unit shows USB and Aux as options on the screen as well.
I put a call into the dealer to see whats up since they advertised the truck as containing USB and Aux (and some other things it didn't come with) and am waiting to hear back what they'll do for me.
1DF57D10-07B3-4732-B344-C4EA686D3097.jpeg A33044A0-C8BF-4707-85CE-0CA8CCFA519A.jpeg E288A3C0-1169-42C5-82C4-CE0772CC4429.jpeg
  • WindowStickerPDF.pdf
duunoit
EcoDiesel
I would check the window sticker (chrysler.com/hostd/windowsticker/getWindowStickerPdf.do?vin=3C6UR5CL8DG529795 [use your vin]) and see if it came with the 8.4 from the factory.
kwend
Twin Cities
2017 Big Horn
See my above post. Window sticker is a .pdf attachment to the post.
chrisbh17
Build sheet is different and more detailed. Try to get that instead.
Sent from my Nexus 6P using Tapatalk
duunoit
EcoDiesel
Oops, sorry about that, wasn't paying attention. Your console doesn't look very deep. I want to say mine is a couple of inches deep (2"-3"?).
kwend
Twin Cities
2017 Big Horn
Build sheet attached. Shows multiple USB and Aux as a part of the build.....
  • BuildSheetServlet.pdf
duunoit
EcoDiesel
It shows the media hub on the build sheet when I put in your vin from the window sticker pdf, but strangely it won't pull your window sticker from the link I posted...
duunoit
EcoDiesel
Works fine on mine (and the example I posted)... Odd.
kwend
Twin Cities
2017 Big Horn
UPDATE
Went and talked to the dealer. Their hypothesis is that since they used this truck as a loaner for a few months, a customer removed the original center console and swapped theirs. That actually makes sense to me.
Now we wait to see if they are willing to help me out on this.
duunoit
EcoDiesel
Wow. Pretty shady. I would think they know who they loaned it to...
kwend
Twin Cities
2017 Big Horn
They’re going to swap out the console for me so all will be good.
duunoit
EcoDiesel
That's cool. Sounds like they're taking care of you.
Kapt
3L
I thought I was the only one that weird things like that happened to :D
