Blendor Actuator?
Discussion in 'Tech Info' started by speeddemon47, Oct 28, 2016.
  1. speeddemon47
    speeddemon47 Junior Member
    Oct 28, 2016
    Ram Year:
    1997
    Engine:
    5.9 Magnum
    I have a 97 1500. I don't have any heat (only lukewarm). both tubes going to the heater core are warm so I don't think it's blocked. I flushed the coolant system. I'm thinking it may be my blendor acuator. It should be a simple process but when I go to the passenger side where it should be I don't see it? All that is there is a round metal post that sticks through the black plenum case. When I move the air settings around the cylinder moves so I know im in the right spot. It's like this is where the blendor actuator should be but there aren't even mounting holes for it. What am I missing?
  2. dapepper9
    dapepper9 Senior Member
    22
    4,779
    1,855
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    I've never really been in there so I'm not really sure what to suggest other than download the factory service manual here and go through that
  3. dodge dude94
    dodge dude94 Senior Member
    23
    27,424
    6,268
    Sep 5, 2013
    East Texas
    Ram Year:
    1998 Ram 1500
    Engine:
    5.9 Magnum
    94-8 there is no blend door actuator. The blend door is controlled by a metal rod that's controlled by a cable from the a/c controls. If your heat is luke warm either the door is stuck/broken or you have a problem with/in your heater core.
Share This Page
