Really a buy back for a brake controller I do not think that will happen, not with out much aggravation of time spent trying to get that to happen jumping threw all the hoops and BS required. Not to mention your truck not able to tow your trailer while you are fighting with RAM!
This should be reported to all agencies I posted if you are truly concerned about your safety and others on the highway which you are responsible for when you tow anything and the load you maybe carrying!
Yes, a buy-back. I've already spoke with an attorney about the issue. Each state has their own lemon laws, in Michigan I can force a buy-back if they cannot fix the issue after four attempts or 30 days in dealer service, whichever comes first. I don't want to do a buy-back, I'll take a fix or a refund for the cost of the ITBM.
As you suggested, I already filed with the NTSB because of the safety issue. The BBB has no interest in this issue. I'm currently working with Chrysler, another member provided a Chrysler contact. I want to run this course before I take any other actions.[/QUOTE]
NOW BACK TO THE PROBLEM
BOSSHOGG
If you say it comes from relay module on the main electrical distribution Circuit= BUS OR BUSS.
Then why not eliminate all the circuitry out of the problem and try running a fused power wire directly to factory brake controller and see if problem is FIXED???
AS I mentioned there may not simply be enough amps threw all the interconnections of the power distribution relay module to give FULL amps to the controller.
KWhite posted a popular web link where anyone can look up the schematic of their vehicle's electrical architecture. This will show how the trailing wiring power is sourced. The graph of the ITBM's ouptut is linear and its behavior does not demonstrate a current starvation issue. This is confirmed by using a trailer brake simulator which only pulls 2 amps at 12 volts.
I mostly deal with German Electrical power since my company services several brands of metal working machinery,lathes,milling machines,surface and cylindrical grinders. We also design and build custom automation systems and robotic systems. I am capable of component level repair of circuit board repairs with associates degree in electronics.
Impressive. I too have a background with electronics and software. I'm retired from GM Powertrain (2006) and now work for a tier one automotive supplier. I lead a team of eight engineers responsible for the electric system architecture and functional integration of a common architecture used in several Ford vehicle platforms. I've been designing hardware and software for just over 40 years and hold a BS in electrical engineering, MS in electrical engineering, BS in software engineering, and a MS in technical management.[/QUOTE]
Frankly BOSSHOGG I do not care if you ever get your problem sorted, as I no longer have a RAM with inferior factory brake controller. You criticize people for trying to help
WOW! Don't understand your hostility and I certantly never criticzed you, I looked back through the thread and didn't see anything that could have offended you.
By the way, BUS (n.) and BUSS (v.) have very different meanings and definitions.
