Kbass6319
I have a 2002 Ram 3500 with 5.9 Cummins and experiencing some brake issues that I'm not sure where to start. Recently, I was pulling a lowboy full of metal roofing and when I came to a stoplight and depressed the brake pedal it went straight to the floor. Thankfully no one was crossing because I blew straight through. I do have minimal brakes on rear so I was able to slowly make it home. The brake and ABS light came on immediately. Check fluid in reservoir and it was empty (was full prior). Once I refilled and press pedal, I figured I would see a leak, but none found. Not really sure where to start with diagnosing the problem so hoping someone here might lead me in the right direction. Before this happened, I had recently changed right front caliper/pads, but everything seemed to be working fine. Any suggestions are greatly appreciated!
