Bring on the Bondo... (long)
Discussion in 'Exterior' started by kdryan, Sep 7, 2016.
Sponsored By: BAK Factory Outlet
  1. kdryan
    kdryan Member
    76
    Oct 11, 2015
    Ram Year:
    1998
    Engine:
    5.2
    Ok, so I have decided to try some body repair. May God have mercy on my soul; this is the point where I either save or destroy this truck. :)
    Here is the rust on my truck. Between this truck and an '84 Mustang, my son and I are keeping pretty busy with projects but this is something I have never tried. I have watched a few videos and I think I have a pretty good grasp of the theory of it and I am reasonably smart (my wife might say different) but it's a little daunting. I wonder if I might get some opinions on each of the sections and what to look out for. The truck is a '98 and started life with those idiotic ground effects everyone loved back in the '90s. I ditched those earlier this summer but I think they did at least keep the rust at bay a bit longer than most trucks enjoy. After all of it is done I'll get under there with some undercoating and spray the hell out of it. Click for Ginormous images...
    Thanks beforehand for any advice you can offer! :)
    Passenger side rocker panel
    Easily the worst area on the truck. Rust has eaten it's way through and is all along the rocker. The inside has heavy surface rust (see the picture of the hole) but is not rusted through. My plan is the sand it down then use a rust converter or remover on the inside. I thought of using a mesh patch on the big hole then just Bondo alone on the rest. After that, primer it up with some spray primer until I can afford to get it painted. BTW, the image is warped. The truck is not dented or anything.
    [​IMG]
    [​IMG]
    Driver side rocker panel
    Not as bad but I'm certain when I get it sanded down it will be worse. Sand it, remove rust, Bondo, primer, live happily ever after...
    [​IMG]
    Passenger side bed behind wheel
    Rinse, Lather, Repeat...
    [​IMG]
    Driver side bed behind wheel
    More of the same. Not rusted through...
    [​IMG]
    Roll pan is chipped
    Obviously not a Bondo area since it flexes but I was thinking of putting a patch on the back then laying down some fiberglass, sanding it down then priming it. The break is about 3" tall by 2" wide at the bottom. Unlike Bondo, I do have minimal experience with using fiberglass so I am fairly confident here.
    [​IMG]
    There are other tiny areas where the trim trapped moisture and rust has started but if I can handle this I certainly can them.
  2. jsmith
    jsmith Senior Member
    276
    101
    Mar 8, 2015
    Ram Year:
    1999
    Engine:
    5.9
    If it were me I'd cut back to good metal and weld in patch panels but if you don't want to try welding they do have some good no-weld patch panel kits out nowadays. Eastwood sells one and I'm sure there's other places too
    marine6212 likes this.
  3. kdryan
    kdryan Member
    76
    Oct 11, 2015
    Ram Year:
    1998
    Engine:
    5.2
    Do you have a link to that? I would be interested. I am not in a position for welding.
  4. dodge dude94
    dodge dude94 Senior Member
    23
    27,478
    6,271
    Sep 5, 2013
    East Texas
    Ram Year:
    1998 Ram 1500
    Engine:
    5.9 Magnum
    I tend to lean toward the rivet-in style patch panels available these days. Bondo WILL crack and fall off within 1-2 years given how much you'll have to use.
  5. 07MegaCabRam
    07MegaCabRam Senior Member
    1,066
    516
    Jun 16, 2014
    Chandler, Arizona
    Ram Year:
    Engine:
    6.7L CTD
    Man, Do I love living in Arizona. None of that crap around here!! Holy hell..
    And do not use the word BONDO. That is the cheap stuff.. and body filler (bondo) shouldn't be around rust at all..
    I worked at a body shop and trust me - this is no easy task, if you have not done this before.. Don't attempt it.
  6. dodge dude94
    23
    27,478
    6,271
    Sep 5, 2013
    East Texas
    Ram Year:
    1998 Ram 1500
    Engine:
    5.9 Magnum
    FWIW, we use EVERCOAT RAGE at work...seems to be alright lol
  7. 07MegaCabRam
    1,066
    516
    Jun 16, 2014
    Chandler, Arizona
    Ram Year:
    Engine:
    6.7L CTD
    Where do you live? Canada? Never wash your salt road gunt away?
  8. dodge dude94
    23
    27,478
    6,271
    Sep 5, 2013
    East Texas
    Ram Year:
    1998 Ram 1500
    Engine:
    5.9 Magnum
    Wut? You talking to me? I work in a collision shop. We don't fix rot or rust. lol
  9. 07MegaCabRam
    1,066
    516
    Jun 16, 2014
    Chandler, Arizona
    Ram Year:
    Engine:
    6.7L CTD
    No, sorry the Op.
    Production collision is where it's at! That is where I was.
  10. kdryan
    kdryan Member
    76
    Oct 11, 2015
    Ram Year:
    1998
    Engine:
    5.2
    Well aren't we just superior... :flipthebird: I've only had the truck a year and the only reasons I bought it were A: So I don't have to drive my 2013 Mustang in the snow and crap, and B: to have something my son and I could work together on. The object here is to learn, not to throw the thing away because we only want to swap out fenders.
    I am not against replacing the rocker panels, in fact I would prefer it but I do not possess a welder, a place to weld, or even welding skills. My first thought was to have a body shop replace them but at $1200 per side it's a bit prohibitive and defeats the learning process. The stick on panels people are talking about here are tempting and using Bondo isn't my first choice; it's simply the most expedient method.
Share This Page
