Bring on the Bondo... (long)
Discussion in 'Exterior' started by kdryan, Sep 7, 2016.
Sponsored By: BAK Factory Outlet
  1. dodge dude94
    dodge dude94 Senior Member
    23
    27,475
    6,271
    Sep 5, 2013
    East Texas
    Ram Year:
    1998 Ram 1500
    Engine:
    5.9 Magnum
    We use panel bond adhesive at work all the time. It's a two-part epoxy and works very well. BUT, surfaces need to be real clean and your work time is a pretty short window.
    I wouldn't see an issue with using panel bond if you have enough clean metal to work with.
    One of my friends replaced most of his cab corners that rotted out and he use panel bond and so far it's holding up just fine, shit is like concrete lol
  2. kdryan
    kdryan Member
    76
    Oct 11, 2015
    Ram Year:
    1998
    Engine:
    5.2
    Ok, so back to work on this...
    I ordered this a couple weeks ago and when it came, needless to say it was a bit large and needed to be cut down...
    [​IMG]
    I went around on the bonding agent and the gun for a bit debating wether to get the cheaper stuff and cheaper gun or just go with the 3m. I got this today in the mail. $80 on Ebay for gun and tube + 2 nozzles...
    [​IMG]
    [​IMG]
    Cleaned up the rocker and the rust turned out to be a bit more extensive than I had anticipated... Paint was completely stripped by the time I was done.
    [​IMG]
    Test fitting the cut down piece
    [​IMG]
    Applied the bonding agent. After this I spread it out with a paintbrush as per instructions.
    [​IMG]
    Went ahead and put a few pop rivets in as well since that area was going to be hidden. Note to self: DO NOT DROP THE PIECE IN THE GRASS WITH BONDING AGENT ON IT! Because I didn't do that... And I didn't have to clean it off with a cloth and do it all over again... No, not me...
    [​IMG]
    Bottom with rivets in place. Should be enough to hold, I think.
    [​IMG]
    3M says give it four hours to dry. I thought about using some body filler on the front seam but I think I won't. Next is to spray primer it then when I get all of the body work done I'll get it painted.
    [​IMG]
    [​IMG]
    Let me say, I understand that this is a very amateurish job and I am certain that many body men out there that see this will be cringing. It is my first attempt of any kind at this and I know I am not any kind of an expert. I will keep this thread going for whatever body work I do from here on out.
    Opinions?
    jsmith and Joe w. like this.
  3. Joe w.
    Joe w. Senior Member
    360
    56
    Aug 12, 2015
    Virginia
    Ram Year:
    1999
    Engine:
    318 5.2l
    Looks good man I wouldn't worry about what someone else thinks
    kdryan likes this.
  4. clownprince
    clownprince Member
    70
    14
    Sep 17, 2014
    Ram Year:
    1997
    Engine:
    Magnum V8
    The reason pro's are pro's is because they do it all the time. A lot of us are amateurs and enjoy doing this stuff. Nice job man, looks good!
    kdryan likes this.
  5. dodge dude94
    23
    27,475
    6,271
    Sep 5, 2013
    East Texas
    Ram Year:
    1998 Ram 1500
    Engine:
    5.9 Magnum
    Hey, it works. My only thing is always make sure ALL the rust has been removed and the whole area behind it shot with rust preventer.
    clownprince likes this.
  6. 15ecodiesel
    15ecodiesel Junior Member
    54
    Aug 27, 2016
    Ram Year:
    Engine:
    Eco diesel
    Here is a site that can help you and your son do this body work it's called learn auto body and paint also has a site on you tube
  7. kdryan
    kdryan Member
    76
    Oct 11, 2015
    Ram Year:
    1998
    Engine:
    5.2
    No link... :naughty:
  8. Jimmy68
    Jimmy68 Senior Member
    1,402
    633
    Aug 30, 2015
    Lethbridge Alberta Canada
    Ram Year:
    2001
    Engine:
    5.2L Magnum
    Ya already did it. It looks good. My way is fill large holes with newspaper and then fill everything with fiberglass. Sand smoothish and finish with bondo. Sand that smoother and paint. Lasts a few years or sell it and shut up. Lol.
    Tremclad rust paint thinned with varsol, use a air sprayer or electric and get a nice looking glossy paint job. Lasts a few years.
    Rusty fenders get a nice Bushwhacker fender flare to cover them up. Truck looks like a million bucks.
    Man, I like that panel cover though.
  9. 15ecodiesel
    54
    Aug 27, 2016
    Ram Year:
    Engine:
    Eco diesel
    Learn auto body and paint.com
  10. marine6212
    marine6212 Member
    44
    34
    Sep 8, 2016
    Ram Year:
    Engine:
    Is there a community college or technical school in your area that teaches welding?
    When I took welding classes people used to drop of their projects all the time for us to weld up! You provide the materials and the get experience welding something different than a coupon!
    Sent from my SM-N920V using Tapatalk
Share This Page
