Need help removing my oil tube that's stuck inside the engine block.
5.2
ThisIf you cant get a pick in there to pull it out, you'll have to drop the pan and drive it out from below.
Do that and you'll have to pull the pan anyways. Drain bolt is able to be threaded into the pan because there's basically a nut inside thats welded to the bottom of the pan. Part of why you need to be careful not to over-tq a drain bolt. You will NOT be able to fish it outKnock it into the pan. U should be able to fish it through the drain.
I would drop the pan bolts slide it over a touch and get up in there and tap it out from inside out then grab w some visegripshello I really need help for my 96 Dodge Ram 5.2 oil is stuck inside the block..
