buying tire chains?
rsdata
N Ky
2014 BigHorn 1500 8spd 4X4
after reading this thread I spent some time looking at youtube videos about all kinds of advanced polymer tire chains, that certainly appeared to me would have no body clearance issues at all... If I needed chains, I would certainly look into and use one of those new S class styles that I saw in the vids
calling them chains maybe is the issue...more like traction aids
Pmexpert
6.4 SRT
Damn, thanks for the info. I foound a tire chanes for 37 tires on theirs webpage...so was thinking to get a set for some extreme conditions...ufff, but sure not from now!
Stockton
Oregon
Forgive my ignorance and apologies for reviving this old thread. I am a new 2018 Ram 1500 owner but I have a question. I used to have an 06 Tacoma and we were told not even to put S-Class chains on the front. Well sometimes I go places where chains are needed so I put 1.75" wheel spacers up front and I was able to run the standard LesSchwab chains so issues on the 4 occasions in 5 years I needed them.
I will be putting the Bilstein front leveling struts on so I can get 33" BFG AT KO3's put on and I am curious if wheel spacers might help with the clearance from suspension components similar to my Tacoma. Obviously there may be issues at full lock and full stuff but a little body trim is fine whereas wrapping chains around suspension components is not.
I have legit chains for the rear and I guess I better test fit those soon since I am not used to having the coil suspension in the rear. I do a lot of winter back country camping/travel and I need to ensure I can get out when a freak snow storm drops more than expected.
BWL
Embrace the skeptisism
BC Canada
If by 33s you mean 33x12.5 then all I can say is test fit keeping in mind they will move a little and slack over time. If by 33s you mean 275 60 20, which is the stock size and also a 33" tire I'd say you'll be fine as long as they're tight and the correct size. I Run the most aggressive tire chains I've ever seen and they clear on my truck fine on that size. I'm going to test fit on my 275 65 20 34" to see how they clear next time I have time.I may upsize my winter tires next time,but wont if chain clearance is an issue. Looking at it I think a larger diameter may give the chains more clearance in the back from suspension and brake lines, but I worry about fender clearance. In the front I wouldn't clear the fenders when turning even stock size at stock height.
McBroom
Denison Tx
Hemi 6.4L
Most rams you aren't suppose to put chains on anyways.
Who told you that Ram trucks ain’t supposed to use chains? Who cares they’re *******’ anyway.
Blue Streak Pearl off-road
McBroom
Denison Tx
Hemi 6.4L
Chains from what I was taught do not go on the front or steer axle of any vehicle
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
That would the the owners manual.......and per that, I can't put chains on my truck's rear axle, and they say not to put them on the front axle...so that means NO CHAINS !
TRCM
USN, Retired
Newport News, VA
You're best to read your owners manual and follow what it says...some models & tire sizes can use them, some can't.
BWL
BC Canada
As a general rule no, but heavy trucks use them for steering and if 1 set can't get you through sometimes 2 will. I've never chained the front, but I see the odd guy do it. On my truck front chains would probably tear stuff up.
Big Terry
Dover OH
Define "heavy truck". Because I'm a truck driver who hauls 80k#, and you will NEVER see a professional driver chain his steers. EVER. Chaining steers is more dangerous than not chaining anything at all.
BWL
BC Canada
I see it all the time out here. Off road in the mud it makes a big difference going around corners and in ice on certain roads where you need to make a turn approaching or coming down a hill. The guys running tri drives do it most often because they really want to go straight. Highway trucks I have no idea.
Big Terry
Dover OH
Ok, off highway definitely makes a difference.
Stockton
Oregon
This is definitely for an off highway back country use. Someplace where I need more grip on the steer axle due to heavy snow or hard packed icy snow. Been in a few situations where the bumper becomes a plow and/or one side of the road is a nasty drop off and having that extra grip is really nice. Never had any issues with how I had my Tacoma set up despite manufacturer warning of no chains on the front. I rarely ever put chains on while highway/city driving as a good set of tires, slightly deflated and knowing how to drive takes care of most the problem where I am from. Just curious if anyone with more knowledge about these trucks has had success chaining all 4 with what I am speaking of.
I have a tradesman express and will be putting 285/70/R17 tires on with the Bilstein struts set at 2.25-2.75 pending what is needed to stop the nose dive.
