DSKUP
Just did this on my 2012 CC. Everything worked as earlier reported. I just thought I'd add one thing. The position of the "cut out" area is such (under dash, all the way to the right) that I had to lay on my back on the floor of the passenger side. Being right handed, I found it a bit of a struggle to get up in there and make the cuts. Just a really awkward position.
The kit I bought included instructions with an optional step of removing the top glove box compartment. It indicated there are a few trim clips and one 7mm bolt holding it in. I didn't do this, as I wanted to limit the amount of disassembly. But in hind sight I can see how it would allow a guy to sit upright and look through the upper opening, while working through the lower opening. So take that for what it's worth.
I did notice a slight reduction in airflow, which is just common sense. On the upside, it tamed the noise of the max fan setting.
Oh, one last thing. I had to twist the filter a bit to get it in place, as there is a bit of a dog leg in going through the dash opening to the slot. Nothing major though.
