LeesEvoX
- Oct 29, 2017
- 1,652
- 2,215
- Location
- Houston, TX
- 2020
- Hemi 6.4l
Mine did the same thing, also a 2012. You just have to play with it a bit... well, a lot lol.Guys, need your help.
Just did my mod today (with bruises and cuts on both hands....) with a boxcutter.....(2012 Sport)
Anyhow, maybe an advise from one of you.
The filter door cover fits perfectly and also seals the filter opening, BUT, I tried and pushed as much as I could, I am unable to latch the door on both sides. It simply doesn't snap in.
I checked for the littel plastic hooks on both sides of the filter housing and they are there.
Is it possible that they are maybe a little bit too long, and that I need to rasp off a bit of the plastic latches from the filter door?
Anyone had a similar issue?
Eventually you will get both sides to clip.
Trying hooking one side on. And then apply pressure to the very edge of the other side. And be pretty forceful
Sent from my SM-G950U using Tapatalk
