California Emissions on a 2011 Ram 3500 Diesel
Discussion in '6.7 Common Rail' started by rdcoleman, Dec 29, 2014.
  1. rdcoleman
    rdcoleman Junior Member
    Dec 29, 2014
    Ram Year:
    Engine:
    Cummins 6.7
    I leave in Michigan and recently purchased 2011 Ram 3500 dually with a Cummings 6.7 diesel that came from California, I'm looking for ways to improve milage and performance and I'm wondering what California emmision can I remove. If anyone knows please respond. If it matters it is 4 wheel drive and has a 410 rear end.
  2. NWRQC
    NWRQC Senior Member
    842
    86
    Sep 5, 2011
    Ram Year:
    Engine:
    In order to remove any of the emission equipment you will need a delete capable tuner first. You could also use SIM's but you will have a CEL on.
    Then you can remove the egr system and replace the exhaust (DPF,NOX,CAT). That will get the engine breathing better and not pumping soot back into the engine.
    You could also contact Anarchy Diesel or Dave at Daconian diensel and tell them what you are wanting to do and they can get you set-up. Both have good prices on the stuff you want/need.
  3. Stangshcky12
    Stangshcky12 Super Moderator Staff Member
    9,057
    888
    Oct 26, 2011
    Oshkosh, WI
    Ram Year:
    Engine:
    5.9 Cummins
    I don't believe the California trucks have anything different from any other trucks anymore
    NWRQC likes this.
  4. NWRQC
    NWRQC Senior Member
    842
    86
    Sep 5, 2011
    Ram Year:
    Engine:
    Agree as well.
  5. swp1983
    swp1983 Junior Member
    34
    23
    Jul 2, 2016
    Ram Year:
    Engine:
    6.7l cummins
    So what happens when you need to get the truck smog checked? I just had my 2012 CT smogged and was told if any of the emissions stuff had beed messed with it would not pass. I guess you need to have a buddy in the smog shop!? interested bc I'm also in California and would like to open her up!
  6. BWC
    BWC Member
    79
    Sep 2, 2015
    Northern CO
    Ram Year:
    2003
    Engine:
    Cummins
    Do you have emissions needed in your area? Thats the big question
  7. Power247
    Power247 Senior Member
    42
    5,506
    809
    Jul 26, 2012
    High Point, NC
    Ram Year:
    Engine:
    CTD 6.7
    If you are in an area that only smogs for yearly inspections you can do a DPF only delete and leave everything else intact and disabled by the tuner. Then, when it's time for recert you put the DPF back on and remove the tuner a few days before inspection.
    Greg
    2012 | RAM 2500 | CCSB | Custom tuned by Double R Diesel
    2016 | Heartland Pioneer | DS310
  8. drittal
    drittal Senior Member
    1,541
    583
    Apr 24, 2015
    E. Montana
    Ram Year:
    Engine:
    6.7
    Is anyone like me and get DPF and DEF mixed up all the time? I think we need more acronyms. EGR, SCR, DEF, DPF, NOX, etc...
    To the OP, my father's 2012 got a ~30% bump in mileage with an 'offroad' package.
    Sent from my SM-N900V using Tapatalk
Share This Page
