cam or gears?
Discussion in 'Tech Info' started by 94ram1500, Jan 9, 2017.
  1. 94ram1500
    94ram1500 Junior Member
    57
    Jan 9, 2017
    Ram Year:
    1994
    Engine:
    5.9
    Hello everyone, question... I have a 94 1500 5.9, bone stock pu, I'm going to be buying and towing a two horse trailer, I haven't bought the trailer yet but I'm guessing between my horses, which average about 1200 a piece, and the trailer itself, the whole tow load will be 5,500-6,000 lbs, What would be the best route for extra power, a cam replacement, or steeper gears , go from 355 to 390's? also will the stock computer be compatible with a new torque profile camshaft?
    Thanks
  2. dudeman2009
    dudeman2009 Senior Member
    22
    1,395
    157
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    Cams really only give a small increase in power on a stock setup. You would be much better off spending the money that you would otherwise put into gears or a cam + equipment to do so, on a tune. That is by far the easiest and most effective way to increase power per dollar.
  3. mda8569
    mda8569 Senior Member
    48
    140
    28
    Dec 13, 2014
    Vandalia Ohio
    Ram Year:
    2001
    Engine:
    5.9 magnum
    If he didnt have an obd1, he could tune for it. Gears, definitely.
  4. dudeman2009
    22
    1,395
    157
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    Engine:
    Magnum 360
    I didnt see the year.
Share This Page
