Can anyone show me there 4" lift on 35's?
Discussion in 'Lifted' started by Orion, Dec 25, 2016.
  1. Orion
    Orion Senior Member
    157
    19
    Aug 2, 2016
    Ram Year:
    2009
    Engine:
    I was told by a Maxtrac rep. that the spacer is no longer required in the front, so i'll simply remove it. BTW the 7" lift is $100 something off. I ordered the 7" lift an hour ago, it was only $1,041.00
    Solid State likes this.
  2. Solid State
    Solid State Senior Member
    463
    177
    Apr 18, 2016
    Ram Year:
    2011 Bighorn
    Engine:
    My bils are @ 2.1, and I still have about an inch rake. I can measure later, but think i'm like 43.5 front, 44.5 rear. Front was originally 36, rear 39.5. Bils make 38 front with 5.5 lift equals 43.5. I have 5" rear springs.
  3. Juvenator93
    Juvenator93 Senior Member
    24
    490
    221
    Oct 8, 2014
    Ram Year:
    Engine:
    43.5 F&R with 2" Thuren coils lol. My 12 1500 was 42.5 F and 43.25 rear with a 4" and Bils at 1.4[​IMG][​IMG][​IMG]
  4. mpittman
    mpittman Senior Member
    210
    68
    Aug 5, 2016
    Indiana
    Ram Year:
    2015 Big Horn Crew Cab
    Engine:
    sounds about right then... you are nearly 7.5" lift in front. And, are you running 35" tires? That's another 1" raise from stock tires.
  5. mpittman
    210
    68
    Aug 5, 2016
    Indiana
    Ram Year:
    Engine:
    [​IMG]
    Got the 4" BDS with Bils at 1.4". Sits dead level and couldn't be happier.
    Jershipe likes this.
  6. SJP_1809
    SJP_1809 Senior Member
    141
    46
    Aug 5, 2016
    Thomasville, GA
    Ram Year:
    Engine:
    Looks good!! What's your fender measurements?
    mpittman likes this.
  7. mpittman
    210
    68
    Aug 5, 2016
    Indiana
    Ram Year:
    Engine:
    43.5" all four corners.
    My fronts started out at 36.5" and rear was 39.5".
  8. joeygster
    joeygster Senior Member
    716
    274
    Sep 21, 2015
    Ancaster, Ontario
    Ram Year:
    Engine:
    So is the consensus among the 4" lift guys that the Bilsteins set at 2.1” leaves with a slight rake & set at 1.4” leaves you level or very close to it?
    Right now I’m Bilsteinless, but considering them for the future.
  9. Jake2544
    Jake2544 Senior Member
    48
    106
    30
    Dec 6, 2015
    MA
    Ram Year:
    Engine:
  10. Synolimit
    Synolimit Senior Member
    108
    14
    Apr 5, 2013
    Ohio
    Ram Year:
    Engine:
    Let me ask you this if you don't mind...I have the OEM sport wheels at +19 with a 10mm spacer. That's 21mm off from you. Would 21mm further in look to stupid for those fender flares? I have 295/65/20 nitto G2's and they stick out about an inch right now. Thanks
Share This Page
