Can I fit 37?
Discussion in 'Lifted' started by steermaster, Nov 5, 2016.
  1. RabidRhino
    RabidRhino Junior Member
    Dec 5, 2016
    Ram Year:
    2002
    Engine:
    5.9 Diesel
    The type of tyre can be instrumental......
    I have a set of 37/12.50-20 Nitto Dune Grapplers off my 03 Durango that I want to fit on an 02 Duallie I'm looking at buying.
    They cleared on my 6" lifted Durango because they had rounded sidewalls but there's no way I could have got aggressive MTs on there with large knobly side lugs as they would have fouled on full lock no matter what offset wheel we used.
    Instead of lift I'm hoping for clearance by fitting a set of Fiberworx fenders. Have you considered changing the body ?
    What about a body lift ?
    I just don't want to alter the suspension after Ram spend so much developing it.
  2. usaf2006
    usaf2006 Senior Member
    3,867
    1,047
    Mar 28, 2014
    Augusta, GA
    Ram Year:
    Engine:
    There's no way you'll be able to put 37s on a stock suspension. Fiberwerx fenders may fit them with a slight lift, but not stock.
  3. Bluesmoke91
    Bluesmoke91 2nd GEN Site Mod Staff Member
    3,160
    233
    Nov 26, 2010
    Baldwin Park, California
    Ram Year:
    Engine:
    I'm running 37x13.5x17 Toyo RTs on a Carli 3" kit with absolutely no rubbing anywhere, any time, in any position. You need offset control arms(carli $950, other brands available) and wheels with at least 5.75" of backspacing. I also have the full Carli rear leaf pack which I've been told is also needed to run 37s. Once I figured out I had everything needed to clear 37s(built my suspension before considering 37s), I bought the right wheels then bought my my 37s.
    [​IMG]
    Sent from my SM-G900V using Tapatalk
    SFD213 likes this.
  4. SFD213
    SFD213 Senior Member
    276
    35
    Jul 1, 2013
    Ram Year:
    Engine:
    Thank you for some hard numbers! You are a legend amongst men! Lol
    Well thats a whole lotta extra work and even more money just to go an extra 2" on the tires. Might just end up going with 35s instead
  5. Bluesmoke91
    3,160
    233
    Nov 26, 2010
    Ram Year:
    Engine:
    Haha no problem bud. Looks wise, I think the 37s are worth it. I've seen the same setup on 35s and it looks good but average. Something about the big tires that gives it an aggressive stance
  6. SFD213
    276
    35
    Jul 1, 2013
    Ram Year:
    Engine:
    I think the 37s look spectacular and its what i want, just not sure if spending that kind if money is worth it on a gasser. Same reason it isnt a full lift. Id rather spend the heavy money on a longer lasting cummins
  7. destroyaYO
    destroyaYO Member
    30
    54
    25
    Nov 22, 2016
    Ram Year:
    Engine:
    5.7L V8 Hemi
    Got any photos of what a cali bro lift is?
  8. Lil_Ram
    Lil_Ram Senior Member
    1,162
    548
    Apr 10, 2015
    Ram Year:
    2003
    Engine:
    Power tech 3.7L
    Here it is we call it bulldogging here high in the front low in the back
    [​IMG]
  9. SFD213
    276
    35
    Jul 1, 2013
    Ram Year:
    Engine:
    Shitloads of nose lift at speeds which is just a fast track to st peter
Share This Page
