I think that the ECU I replaced last summer died again. (Cranks but doesn't fire, and the ODBDII interface won't connect) If it is reasonable, I'd like to get it to run long enough to drive the 4 miles to the shop that will look at it rather than hassling with getting it towed.) I know that at minimum, I'd have to jump the fuel system and ASD relays. Anything else, or is the engine not going to start with out a functioning ECU?
Also, the issue seems to have happened at the same time my battery froze. (It was under a year old and defective. I replaced it under warranty only to discover the dead ECU.) Dumb coincidence or could one have caused the other? Anything else I may want to check on to make sure there isn't some other root cause both killing batteries and/or ECUs?
