Truck died one day and wouldn't start. After replacing 200 bucks worth of sensors no luck. I check the power to ASD relay and there is nothing. That ended up being a fuse so no worries. Downer is the ASD relay still remains opened and won't let power through. I jumped a wire from 30 to 87. Truck starts but runs rough and on sometimes when I turn my key off the truck will stay on. No check engine light. I did the trick of turning the key to on and off 3 times to get a code. Don't recall of the top of my head but it says something is wrong with the wiring to ASD and other fuses. Could this be the Fusible link? If so where are they located?
