just because the linkage is there and moving does not mean it is adjusted properly. to me it sounds like it is not adjusted properly if you have to let off the gas for it to shift. mine usually shifts from 1st to 2nd at about 30mph under full throttle no matter what and possibly sooner under lighter throttle. can you throw it in 2nd gear manually and run it past 50mph?The linkage is good. All where it's supposed to be, and moves how it's supposed to move!
