Nealuss
- Mar 8, 2016
- 137
- 33
- 1994
- 5.2L 318
So my truck is a '94 1500 318 with a little over 300k and for the past 2 or so years I have been going through everything trying to get all of the little high mileage 24 year old truck problems worked out before the real restoration/build starts. Lately the big problem is I can't seem to get rid of this horrendous pulley/belt noise. It has a new water pump, new fan clutch, new a/c compressor, new p/s pump, new idler pulley, new tensioner, and new belt. Belt and tensioner and alternator have all been replaced at least 3 times in the past 6-8 months. If I replace the tensioner it will go away for about 2-3 weeks and then it slowly comes back. I thought about going to the dealer and getting the Mopar tensioner and belt after hearing that aftermarket tensioners can be problematic. This time when I started diagnosing the issue I sprayed silicone spray on the belt and it went away for a few minutes, sprayed the tensioner with the same result, then I sprayed the alternator pulley (from the inside away from the belt) and the problem went away instantly and stayed gone for a good 30 minutes. Obviously this sounds like a bad alternator bearing but I have replaced it several times too! What am I missing here? What do I need to do to get rid of this permanently? Has anyone else had this issue?
