Cant raise wot shift points!!
Discussion in 'Engine & Performance' started by Jerseymike, May 19, 2014.
Sponsored By: Moe's Performance
  1. Jerseymike
    Jerseymike Senior Member
    561
    84
    Jul 3, 2013
    Ram Year:
    Engine:
    So my 1-2 shift is at 6000 and 2-4 shift is at 5700. I would like to shift around 6100 but cant go any higher with the tuner. I tried adjusting the tune, then tried going back to stock then reloading the HF tune, then tried going back to stock-updated the tuner- then reloaded HF tune. No change. WTF. Is anyone with a 13 or 14 six speed trans shifting above 6k??? I dont even mind the 6k so much but the 2-4 shifting at 5700 is a doggg.:shrug:
    I posted on the DS forum and am waiting for a reply.
  2. ericlee9386
    ericlee9386 Senior Member
    31
    176
    14
    Dec 4, 2011
    Ram Year:
    Engine:
    My 11 won't shift pass 5990 period. Even set at 6200 it bangs off the limiter at 5980 according to data logs. It probably will take awhile longer to get there.
  3. RAMWarrior1
    RAMWarrior1 Member
    94
    Jan 29, 2014
    South Texas
    Ram Year:
    Engine:
    Latest Intune Update?
    What's the latest Intune Update? I can't figure out how to update it?
    Nevermind, just figured it out.
  4. Jerseymike
    561
    84
    Jul 3, 2013
    Ram Year:
    Engine:
    Did you raise the limiter? There are plenty of guys with 11s shifting at 6200. My truck was shifting at 6100 when I first got the tune but after switching tunes then back again now it wont go back. I hope the guys at DS can figure it out.
  5. ericlee9386
    31
    176
    14
    Dec 4, 2011
    Ram Year:
    Engine:
    Yes I have raised the limiter and had Sean do the same no dice. I have given up on it as of right now lol.
  6. HLram
    HLram Senior Member
    1,174
    214
    Dec 22, 2012
    Ram Year:
    2012 and 2007
    Engine:
    Hemi 5.7 in both
    Can you put the truck in third so it won't shift from second to fourth? That way it'll split that gear shift without such a big drop in rpms. Is it bad to let it shift like that with the "2nd prime" whatever it is called?
  7. 2012ramHEMI
    2012ramHEMI Member
    27
    57
    Feb 27, 2014
    Houma, LA
    Ram Year:
    Engine:
    5.7L HEMI
    Im shifting @ 6200 with my hemifever tune, maybe email sean and see what he has to say
  8. Jerseymike
    561
    84
    Jul 3, 2013
    Ram Year:
    Engine:
    I went back to stock then to Diablo tune then to HF tune. So now 1-2 is shifting at 6200 but 2-3 or 2-4 is still at 5700. Mike at DS said he would take a look at it. There is a thread on their forum with a few guys with the same issue that they fixed. It is an adjustment in the tuner so it should work.
  9. Jerseymike
    561
    84
    Jul 3, 2013
    Ram Year:
    Engine:
    I do it like that sometimes but I missed a shift once and hit the rev limiter, so I dont want to do that. Mike from DS is going to check it out, they have fixed a bunch of tunes. I got the 1-2 to shift at 6200 just need to fix the 2-4 shift now.
  10. UneasyJmitchell
    UneasyJmitchell Senior Member
    510
    70
    Apr 4, 2014
    Louisiana
    Ram Year:
    Engine:
    OMG, I havent even had my hemi to 4k rpms yet, I bet 6k sounds like a monster under the hood!
Share This Page
