Cargo Hooks
BWL
Embrace the skeptisism
BC Canada
IMG_20171126_120427.jpg IMG_20171126_120454(1).jpg I built these tie down rails that go around the wheel wells. They fit in nicely and still clear my bed extender. Also have pop up tie downs in the stake pockets so I can tie stuff down on top of the tonneau and bigger things without cramming my hand into the bed trying to hook up my straps
Skubasteve!
I run two chains, one on each side, front to back. I connect it to the factory tie downs using a caribeaner, and that way I have virtually unlimited tie down points.
Something similar to this, but obviously ours are lower.
iLLeStEyECoN
Tamarac
HEMI 5.7
I too am interested as many new RAM trucks are coming with the rail system and spray in bed liner. They came with 4 rings. I am also planning on getting the cargo divider.
M
Mike Ruocco
Flower Mound Texas
Mine does not have a spot on the top like that for a ring. All four are close to the bed floor. I did order some bullrings for the front 2 holes under the rail. I see the holes in the bed for the ram cargo system but I called the dealer and they can not find the parts for it yet.
BWL
BC Canada
The bull rings for the front fit in the rear as well. You just have to cut out the cut out with a knife.the inner and outer edges are spot on, but you need to leave about a quarter inch on the front and back. I just cut out the front where I had to and used it as a template centred in the cut out for the back ones. The stake holes are there.
BWL
BC Canada
Also can get something like the slide n lock rail system. Rail bolts to the floor or bed rail inside edges and the hooks can be moved along it. They'd get in the way on the sides for me because of the tonneau and I don't like the floor ones because I don't like cleaning them out, but could be an option depending on what you need and have.
iLLeStEyECoN
Tamarac
HEMI 5.7
Was the OP referring to these? This is what I’m referring to that came with my truck. I want more of those. I also plan to get the cargo divider that slides into those rails.
M
Mike Ruocco
Flower Mound Texas
That's what I want! But the dealer cannot find the parts! Can you see any part numbers on the rails and hooks?
iLLeStEyECoN
Tamarac
HEMI 5.7
M
Mike Ruocco
Flower Mound Texas
wutech
SE WI
Figured lol. This system is awesome. Not sure if linking is allowed on this forum, but here you go, for a short bed.
https://moparonlineparts.com/mobile/1500-pickup-utility-rails-p-8700.html
They also have them for the regular bed. I haven’t been able to find extra hooks.
Man I want these, just can’t afford them right now. Hitting g max out of pocket I. Health insurance before the year is half over results in some big bills to pay.
iLLeStEyECoN
Tamarac
HEMI 5.7
I didn’t want to shell out more after my purchase than I had to so I decided I wanted the truck optioned with the bed option, which brings the liner, the lights, and the rail system/hooks
chrisbh17
iLLeStEyECoN
Tamarac
HEMI 5.7
Are these for 2019 only?
Sent from my Nexus 6P using Tapatalk
I’m not sure. I don’t think so as that site has them listed under the previous gen as well.
