Carven Exhaust Install.
BAMF
Southern Louisiana
2015 Big Horn
My carven came out of the clamp. I guess I didn't have it centered. Does anyone know the torque of the clamp? I tossed my installation instructions
Sent from my SM-N910V using Tapatalk
R.L.K.
R.L.K.
Bristol , Tn.
I just centered and tightened mine up pretty good ...as far as tq goes I'd say approximately 300 - 360 inch pounds //25- 30 foot pounds ...
BAMF
Southern Louisiana
2015 Big Horn
I was thinking it was around 250....but that was over a year ago I put it on
R.L.K.
R.L.K.
Bristol , Tn.
I probably put about 350" lbs on mine & they were tight when I removed it after over a year ...I'd say an extra 50" lbs wouldn't hurt a 15mm nut .
Hope this helps !!
BAMF
Southern Louisiana
2015 Big Horn
Hope this helps !!
Thanks.... That sounds about right.... I think I'll split the difference 330. I emailed carven to see but I know I won't get a response this weekend.
unxpctd
Minnesota
2021 PW 75A
I installed my Carven by myself in late August with 500 miles on my Rebel. Currently have 3800 miles on it. The Carven 5" black tips lined up perfectly. I 'm keeping an eye on them and any movement I'll get the exhaust spot welded down after readjusting.
I had my first oil change Thursday and the mechanic said that everything looked good and the collar sleeve bolts were very tight. I must have done something right!
BAMF
Southern Louisiana
2015 Big Horn
The customer service at Carven is rediculously good! This is the second time they have impressed me. I questioned them about the torque and they said it was 40 ft lbs but they are affraid the integrity of my clamps were compromised (which was my mistake for not centering them right when I first installed the exhaust). They sent me all new clamps at no charge! Just got them today.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Instead of putting OEM back on why not go with something like a 24" Magnaflow (Mufflex).
If not, definitely by the 5" tips from Moe's (Mufflex). They actually make the stock a little more audible and deeper. To my ear it makes the stock beast sound like it does on high idle at start up, instead of ho-hum on low idle.
BAMF
Southern Louisiana
2015 Big Horn
I am not going oem. After my carven I will never have another exhaust.... I love it
socal swagger
do you guys prefer the bolt on vs the weld on? I am looking to buy and I am thinking of just having it welded on.
Any problems with a competitor series weld on? Any tips....
Witch
Hemi 5.7 liter
I think welding is a better solution just will need a wye pipe
Nick@GotExhaust
Preferred Vendor
SC
there is no issues getting it welded in. although Carven made revisions and there is no need, the bolt im muffler kits have no issues now
BAMF
Southern Louisiana
2015 Big Horn
I have the bolt on, I prefer it because it is just more convenient. One piece, unbolt the factory muffler and bolt on the carven. No need to go to a welding shop.
R.L.K.
R.L.K.
Bristol , Tn.
And you just do it yourself ????why pay someone to do something to your 30k + investment that requires a 3rd grade education....
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
xxxxxxxxxx
Bolt on all the way. Why even have to deal with finding a welder with a lift when a floor jack, a couple of jack stands and a 15mm socket make it job done?!
daveray9
If you live on the rust belt... it might be worth paying for it.
Sent from my SM-G920V using Tapatalk
Bo Daggart
5.7L
My Carven competitor exhaust has an annoying (not to me but I can see how it would annoy others) drone when I have the cruise control set at 60 mph. My radio usually drowns that out though
daveray9
Shut off MDS and it goes away.
345growler
Ozarks AR
May-13
So far .....pedal commander, Spectre Cai, 93superchip tune, ultra platinum pensoil .......heat tape for the airbox and Intake and competitor muffler be here Wednesday!
Stoked beyond belief! I'll upload when installed.
