cat converter...
nim81
Fredericktown, MO
5.7L
wanting to install a e-cutout before the cat, but the cat seems to be welded directly to the y-pipe from the manifolds, where can i get a new y-pipe that will fit my stock manifolds ? i will be getting shorty headers in a couple months so i need something that will work with them as well and i'll be moving the cat a lil further down the line... any suggestions?
i want the y-pipe to come out at the stock position, and directly into the e-cutout then to the cat, and into my si/do magnaflow. does this sound right?
ramhunter9
P-Star Jeep Wrangler
does your state law make you leave the cat on ?
Why do you want to put it infront of the cat? That is going to throw a code when you open the cutout.
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
only certain counties here in MO do a sniff test - or even look for the cats. I think thats only in STL and KC (and surrounding counties) - he's outside of those and should be able to play.
nim81
nim81
Fredericktown, MO
5.7L
yes they are very leaniant down here in the styx and dont do any emissions testing, only safety inspection..
i would just use the non-fouler trick for any codes that would pop. i want full unrestricted flow when open, just need to fine a y-pipe and cant track one down
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
good ole 02 5.9...i have the same thing.lol
like stated, just do it after the cat.so much easier.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I moved my 30" Magnaflow si/do muffler as far back as I could. Then I moved my cat back behind the trans cross member. This gives me a straight 3" pipe forward to my y pipe. I have plenty of room for a ecutout and since you have a QC you would have room for the cutout and LT's. I did mine in preparation for the LT install.
nim81
nim81
Fredericktown, MO
5.7L
sounds like a good idea! i like this much!! now you have me thinking, more $$$$
Redneck
Springfield, Il
5.9 CTD
Hey RH I think cats are a federal law. But you know my attitude. "F them it they can't take a joke.:upyours:
