Catch me if you can (MPG)
Discussion in 'VP44 Pump' started by Mopar1973Man, Aug 28, 2011.
  1. Mopar1973Man
    Mopar1973Man Senior Member
    47
    825
    Aug 22, 2011
    New Meadows, Idaho
    Ram Year:
    1996, 2002
    Engine:
    1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
  2. ramhunter9
    ramhunter9 Supporting Member
    24,508
    886
    Jun 25, 2010
    Ram Year:
    Engine:
    P-Star Jeep Wrangler
    Nice ... I am at 21-22 right now . Better than the last truck when I got 10
  3. Mopar1973Man
    47
    825
    Aug 22, 2011
    New Meadows, Idaho
    Ram Year:
    1996, 2002
    Engine:
    This is twice as good as the other truck... 96 Ram 1500 5.9L Auto (12-13 MPG)
  4. wermbang
    wermbang Senior Member
    35
    9,707
    172
    Iowa
    Ram Year:
    2001 Off Road
    Engine:
    5.9L V8 Sport
    Haha, I get those in my dreams.
  5. stodg73
    stodg73 Junior Member
    18
    Aug 22, 2011
    Southern Colorado
    Ram Year:
    2001.5
    Engine:
    Cummins
    Hey, MM, I am close to you at 21mpg at 75+mph.
  6. Mopar1973Man
    47
    825
    Aug 22, 2011
    New Meadows, Idaho
    Ram Year:
    1996, 2002
    Engine:
    Thing is... Its no dream... Its real!!! :naughty:
    I've keep a fuel log since 20K miles... I know I need a update pic but...
    [​IMG]
    Catch me if you can...
  7. MarbleCrusher
    MarbleCrusher Member
    73
    Aug 22, 2011
    North Texas
    Ram Year:
    2002
    Engine:
    VP Cummins
    Hey Mike what unit is it that you use that shows your GPH and mph and mpg and everything, as we all know the factory read out is far from accurate and all Ive been doing is hand calculating all along.
    -Jordan-
  8. swamp_life hemi 05
    swamp_life hemi 05 Senior Member
    28
    2,641
    60
    Jul 14, 2011
    Tallahassee Fl.
    Ram Year:
    2005 laramie
    Engine:
    Gettin 22mpg doin 55 mph in mine!
    Incredible 2 on the move!
  9. Mopar1973Man
    47
    825
    Aug 22, 2011
    New Meadows, Idaho
    Ram Year:
    1996, 2002
    Engine:
    That is a ScanGauge II (www.scangauge.com)...
    ScanGauge II you have to calibrate to the GPH and Speed sensors of the truck to get proper readings. Because believe it or not ScanGauge II uses only those 2 values.
    Speed (MPH) / Flow (GPH) = MPG
    55 MPH / 2.30 GPH = 23.9 MPG
    So how did I get it calibrated?
    Simple... Use a GPS and set the offset of speed on the SGII. Mine is 1% off.
    Then as for the GPH offset. You have to fill up at a fuel station let the pump click off by itself don't top off the tank. Then drive thru 3/4 of tank and return back to the very same pump in the same direction. Fill up again the same way. Now the SGII will report the gallons use its see now you adjust the offset to match the gallons on the pump. Once done leave it alone. Don't have to do this over and over again.
    Like on my truck speed is 1% off and GPH is 24% off.
    Like on Mom's 96 speed is 0% off and GPH is 233% off.
    I've used it during the period my fuel sender died as a fuel gauge so I would run out of fuel. The funny part was it was really close to being dead on everytime. Reason why its not... Because I found out from weights and measures there is a small amount of error allowed in the pumps so getting fuel at one spot might give you a bit more where another might not.
    My numbers are closer to correct on the SGII because my odometer on the dash is off by 0.5 MPH so in a tank of fuel the odometer is off by about 15-20 Miles...
  10. 0212353
    0212353 Vendor
    26,332
    1,717
    Florissant, MO
    Ram Year:
    2010 1500 Crew, 2016 1500 Crew & 2015 Charger SRT392
    Engine:
    2x 5.7L & 6.4L
    Does it count if its my minivan that catches you? :D
Share This Page
