CEL and remote start
Sticks2010
Central, NJ
Hey everyone truck issues looking for direction. 2010 2500 5.7L CEL on without code and truck will not stay running more then 30 seconds using factory remote start. " remote start disabled - system fault"
Any ideas? Thanks
Sent from my XT1080 using Tapatalk
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Try disconnecting your negative battery terminal for 30 minutes to reset your computer. This may clear the code and allow you to use the remote start.
Otherwise, you will need to hook it up to a high end scan tool to see what the stored code is.
southernbnb
Not much help but I have noticed that my remote start doesn't want to work properly if my CEL is on. (Mine is currently on due to the egr valve needing replaced). So it very well has something to do with it. Ty resetting the CEL like stated above and see if that helps. At least gives you somewhere to start.
jwheeler
Washington
If the check engine light is on, there is a code in the system. See what it is. The remote start is disabled because of this.
