I just did a test drive in my '98 2500 gas (5.9L) 4x4. I just replaced the catalytic converter and both O2 sensors, put on a new AT fluid filter and new fluid.
After a brief run, I topped off the AT fluid and fixed the front O2 sensor (I didn't have the plug fully connected)
I cleared the ECU errors that the bad O2 sensor caused, and the engine ran fine with no codes.
However, the transmission now doesn't want to shift out of first.
Is this a known issue from me doing something dumb? Would the ECU keep the transmission in limp mode after I cleared the fault codes? Do I need to somehow bleed air from the system from somewhere?
Sent from my SM-G950U using Tapatalk
