Changed trans now OD not working
riturbo
94 ram 2500
Hey guys changed out my trans from my 97 to my 2000 . Everything works fine except it wont shift into over drive or forth gear . Any ideas what it could be . Thanks
jlbayes
2001 & 1997
5.9l cummins
You need the electronics from the 2000my transmission.
R
riturbo
94 ram 2500
Which eltronics are you talking about . Any more details would help . Could you explain it a little more .
Thanks
dapepper9
Iowa/Nebraska Border
5.9L V8
The 2000+ governor transducer and the 2000+ torque coverter clutch /overdrive solenoid pack.
Edit: and the 98.5+ neutral safety
jlbayes
2001 & 1997
5.9l cummins
@riturbo they bolt to the valve body. The neutral safety is external.
R
riturbo
94 ram 2500
Thanks guys . I guess the neutral safety must have been the plug i changed out with the three wires on the back top of the trans . Used the plug from the truck I took the trans from . That seems to be working .
Will it hurt anything to drive it as is ? Right now its in full plow mode with the sander and plow mounted . Is this something I can do myself or should I just drop it off to a trans shop .Not like I haven't been in the pan before .
can I just pull the whole valve body out of my old trans and switch it or should I just buy the stuff I need new .
dapepper9
5.9L V8
On a budget you can swap the old electronics while leaving valvebody in the trans. Otherwise just get new. Can swap valvebody as well but that's no easier of a job
