Lethalweapon100
Hey everybody. This question kind of applies to any 46/47/48 RE/RH transmission.
When I got my truck it had 205K on the clock, probably its 2nd 46RE. So, I dropped the pan and changed the fluid and filter. Since I did it the first time, I try to do it at least once every 12K. My pan has an aftermarket drain plug, so sometimes I just drain and refill if I did the filter relatively recently.
Now, it seems like every time I mention the fact that I do this to somebody, they make a huge point of "that's bad, you shouldn't do that." Every time, their reasoning is the old idea that changing the fluid/filter/dropping the pan "stirs up all the crap" and will end up taking out the tranny faster than if you didn't change the fluid.
I can see how this makes sense if you were to flush a non-serviceable transmission (meaning no detachable pan), but I'm curious as to the truth to this when you can drop the pan and clean it/the magnet and change the filter.
Thanks all! Only asking because I may be picking up a 1st Gen that will be seeing tranny work.
