thanks, I was gonna take it to the dealer and next Thursday apparently that's the earliest they can take the truck in lol. So I should continue to use it normally? I was gonna keep it stationary until thursday.It usually takes a few key cycles before it will go off by itself.
I’m no longer getting the message, thanks guys ! @stimpy433If it was the cap and tightening fixes it, typically the light will go off during your next drive after 20 miles or so. If it doesn't go off, then after a few key cycles you might throw a CEL. If that happens, then you still may not have tightened the gas cap enough, the tether could be stiff causing it to loosen slightly, you could just have a compromised gas cap, or there could be an evap leak.
With that said, hopefully tightening it did the trick. Otherwise, remove the tether and see if it goes away. If not, then just take it to the dealer at that point to diagnose the issue. I'm only recommending the dealer if you are under warranty or have a thick wallet, lol...
