Class Action 6.7L
Discussion in '6.7 Common Rail' started by Keep It Cummins, May 22, 2013.
  1. Keep It Cummins
    Keep It Cummins Junior Member
    19
    Jan 28, 2013
    Ram Year:
    Engine:
    Cummins ISB 6.7 L
    Does anyone know of a class action filed against Dodge and/or Cummins relating to the 6.7L Cummins diesel? Issues regarding too frequent oil change interval, increasing oil level in crankcase, EGR and DPF issues etc.? I didn't spend $40K to buy a 2012 Cummins engine that calls (as per EVIC) for an oil change every 1500 miles. Then after changing oil finding the oil level rising with lab sampling that indicates fuel contamination. Or, I spend my time and money to go for a highway ride for 45 minutes to passively regenerate a DPF filter. Finally, have a dealership snub it's nose at my reguest to address theses problems. These notions were NOT mentioned to me when I purchased the truck. Anyone follow or share my frustration here???
    Thanks!
  2. kcbigbadram
    kcbigbadram Senior Member
    501
    185
    Jul 19, 2012
    kansas city
    Ram Year:
    Engine:
    HEMI
    havent had mine long enough to experience those things myself, but i have read plenty of people having close to same experience. it seems to happen with the trucks that arent getting worked hard.
  3. Wandell
    Wandell Senior Member
    952
    249
    Oct 2, 2012
    Ram Year:
    Engine:
    Cummins 6.7
    A lot of people have solved these issues by deleting these trucks. But the issues you mentioned are pretty much common knowledge about the 6.7's.
  4. BlackedOutHemi
    BlackedOutHemi Senior Member
    23
    5,462
    186
    Feb 27, 2011
    DFW, Texas
    Ram Year:
    2012 & 2012
    Engine:
    5.7L HEMI & 6.7L Cummins
    If its used as a diesel should be used it'll be fine. If you bought it just to have a diesel and no other reason. You've got a problem.
    ceide4489, jlb and oilfieldtrash83 like this.
  5. oilfieldtrash83
    oilfieldtrash83 Member
    91
    May 26, 2012
    North central Montana
    Ram Year:
    2010 LB CC Diesel
    Engine:
    6.7 CTD
    If you bought it as a car to bomb around town then you are going to have issues. Any diesel with a DPF is going to experience the same problems under those driving conditions. Cummins may be a little worse but not much. Mine doesn't make extra oil and never tells me to drive to regen because mine sees highway. Nevertheless, its still going to get the DPF and EGR deleted.
  6. USMC1188
    USMC1188 Senior Member
    1,901
    206
    Feb 14, 2012
    Hamilton, Ohio
    Ram Year:
    Engine:
    5.9 Cummins
    The oil level rising and fuel contamination really doesn't have ANYTHING to do with the EGR or any of the emissions issues. That is your fuel injectors leaking... and if you don't have that issue resolved fairly quickly, you will have way more issues than you are dealing with now.
    And where did you see 1500 mile oil changes?
  7. NWRQC
    NWRQC Senior Member
    842
    86
    Sep 5, 2011
    Ram Year:
    Engine:
    The oil level rising due to fuel contamination comes from the regen process. Although you could obviously have other issues ( like you mebtion an injector) but its common for DPF/emission equipment intact trucks to make oil between changes. I personally have never had that problem, but then again I don't know what happened to my stock exhaust, it went missing shortly after I bought the truck.
  8. USMC1188
    1,901
    206
    Feb 14, 2012
    Hamilton, Ohio
    Ram Year:
    Engine:
    5.9 Cummins
    Interesting, I still am not 100% sure how that would be possible, but then again, I have never had to deal with that issue, so I completely believe that it could happen.
    Thanks for the info though
    NWRQC likes this.
  9. Ram725
    Ram725 Senior Member
    178
    12
    Apr 17, 2013
    Jackson TN/Houston Tx
    Ram Year:
    2012 Ram 2500 Crew 4x4
    Engine:
    6.7 Cummins HO
    My 2012 2500 wont be worked too hard. Just a daily driver. But I have a warranty...
    Probably in a year or two I will be doing deletes.
    Its common knowledge that diesels need extra work, maintenance, and cost more to maintain. No diesel is perfect or cheap to drive. They cost more. But they are worth it in my opinion. I went to a 1500 because I didnt need a diesel and because it would be cheaper to maintain. 8 months and 12k miles later and I am back in a Cummins
  10. NWRQC
    NWRQC Senior Member
    842
    86
    Sep 5, 2011
    Ram Year:
    Engine:
    I haven't researched it enough to give a good answer, so I can only go on the posts that I have read...All I know is that fuel is injected on the exhaust stroke during regen. It looks like I may have some reading to do. I've never been concerned with the process, but now I'm curious.. I've just seen countless "Cummins making oil" posts... :)
Share This Page
