Cluster issue, Check engine light burnt out?
HemipoweredMega
I was trying to troubleshoot a seperate issue when I noticed the check engine light on my dash is not working properly. It will not turn on, even before start-up. I did the instrument cluster reset, holding in on the trip button while turning the key to on. Nearly every single other light works except for the ones for features my truck doesn't have, and the check engine light. I have had the truck just over a year and have never seen it on but I have been able to pull codes off the computer that should have triggered it. I'm guessing I'm not going to be able to buy a bulb for that, so I'm wondering if I am going to have to replace the entire cluster? All of the gauges work perfect just no CEL. Truck is a 2008 Ram 1500 Mega cab. Photo is of the truck with key just switched to the on position, just before start-up.
