ramhunter9
- Jun 25, 2010
- 24,464
- 975
- 2012
- P-Star Jeep Wrangler
Dodge Cummins Check Engine Error Codes
Cycle Key on-off-on-off-on to read codes in odometer display
P0002 ECM fuel calibration error
P0016 Crankshaft/Camshaft Timing Misalignment/Out-of- Sync
P0071 Ambient Temperature Sensor Performance / Rationality
P0072 Ambient Temperature Sensor Low
P0073 Ambient Temperature Sensor High
P0088 Fuel Rail Pressure Too High
P0106 Manifold Absolute Pressure Sensor Performance / Rationality
P0107 Manifold Absolute Pressure Sensor Low
P0108 Manifold Absolute Pressure Sensor High
P0111 Intake Air / Charge Temperature Sensor Performance / Rationality
P0112 Intake Air / Charge Temperature Sensor Low
P0113 Intake Air / Charge Temperature Sensor High
P0116 Engine Coolant Temperature Sensor Performance / Rationality
P0117 Engine Coolant Temperature Sensor Low
P0118 Engine Coolant Temperature Sensor High
P0121 Accelerator Position Sensor (APPS) Signal Voltage Too Low
P0122 Accelerator Position Sensor (APPS) LowAPPS Voltage Input Too Low
P0123 Accelerator Position Sensor (APPS) Signal Voltage Too High
P0128 Cooling System Error / Thermostat Rationality
P0148 Fuel Delivery Error
P0168 Fuel Temp Too High
P0169 Water-in-Fuel Detected For Too Long
P0192 Fuel Rail Pressure Sensor Low
P0193 Fuel Rail Pressure Sensor High
P0201 Fuel Injector 1 Circuit
P0202 Fuel Injector 2 Circuit
P0203 Fuel Injector 3 Circuit
P0204 Fuel Injector 4 Circuit
P0205 Fuel Injector 5 Circuit
P0206 Fuel Injector 6 Circuit
P0216 Fuel Injection pump Timing Malfunciton [new injector pump time]
P0217 Coolant Temperature Too High
P0219 Engine Overspeed
P0230 Transfer pump circuit out of range
P0234 Turbocharger Overboost Condition
P0235 Turbocharger Boost Sensor A Circuit
P0236 Turbocharger Boost Pressure Sensor Performance / Rationality
P0237 Turbocharger Boost Pressure Sensor Low
P0238 Turbocharger Boost Pressure Sensor High
P0251 Fuel Injection Pump Mechanical Failure Fuel Valve Feedback Circuit
P0252 Injection Pump Fuel Metering Control "A" Range/Performance
P0253 Fuel Injection Pump Fuel Valve Open Circuit
P0254 Fuel Injection Pump Fuel Valve Current Too High
P0300 Multiple Cylinder Misfire
P0301 Cylinder 1 Misfire
P0302 Cylinder 2 Misfire
P0303 Cylinder 3 Misfire
P0304 Cylinder 4 Misfire
P0305 Cylinder 5 Misfire
P0306 Cylinder 6 Misfire
P0335 Crankshaft Position Sensor Circuit
P0336 Crankshaft Position Sensor Performance
P0337 Crankshaft Position Sensor Circuit Low
P0338 Crankshaft Position Sensor Circuit High
P0340 Camshaft Position Sensor Circuit
P0341 Camshaft Position Sensor Performance / Rationality
P0370 Timing Reference High Resolution Signal "A"
P0380 Intake Air Heater #1 Control circuit
P0381 Wait-to-Start Lamp Inoperative
P0382 Intake Air Heater #2 Control circuit
P0460 Fuel Level Sensor A Circuit
P0461 Fuel Level Sensor 1 Performance / Rationality
P0462 Fuel Level Sensor 1 Low
P0463 Fuel Level Sensor 1 High
P0477 Exhaust Pressure Control Relay Low
P0478 Exhaust Pressure Control Relay High
P0480 Cooling Fan 1 Control Circuit/Open (Low Speed Fan Relay)
P0483 Cooling Fan Speed
P0500 Vehicle Speed Sensor 1 Circuit, or No Vehicle Speed Reference Signal 1
P0514 Battery Temperature Sensor Performance / Rationality
P0516 Battery Temperature Sensor Low
P0517 Battery Temperature Sensor High
P0521 Oil Pressure Sensor Performance / Rationality
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Input
P0523 Oil Pressure Sending Unit Voltage too high
P0524 Oil Pressure Too Low
P0532 A/C Pressure Sensor Low
P0533 A/C Pressure Sensor High
P0541 Intake Air Heater Relay 1 Low
P0542 Intake Air Heater Relay 1 High
P0562 Battery Voltage Low
P0563 Battery Voltage High
P0572 Brake Switch 1 Low
P0573 Brake Switch 1 High
P0576 Cruise Control Input Circuit Low
P0580 Speed Control Multiplexed Switch 1 Low
P0581 Speed Control Multiplexed Switch 1 High
P0602 Control Module Programming Error/NotProgrammed
P0604 Internal Control Module RAM Integrity Failure
P0606 Internal ECM Processor
P0607 ECU Internal Performance
P0622 Generator Field Control Circuit
P0628 Fuel Pump Relay Circuit Low, or Fuel Lift Pump Control Circuit Low
P0629 Fuel Pump Relay Circuit High, or Fuel Lift Pump Control Circuit High
P0630 VIN Not Programmed in PCM
P0633 SKIM Key Not Programmed in PCM
P0642 Sensor Reference Voltage 1 Circuit Low
P0643 Sensor Reference Voltage 1 Circuit High
P0646 A/C Clutch Relay Circuit Low
P0647 A/C Clutch Relay Circuit High
P0652 Sensor Reference Voltage 2 Circuit Low
P0653 Sensor Reference Voltage 2 Circuit High
P0698 Sensor Reference Voltage 3 Circuit Low
P0699 Sensor Reference Voltage 3 Circuit High
P0700 Transmission Control System (MIL Request)
P0743 Torque Converter Clutch Circuit Electrical
P0753 Shift Solenoid "A" Electrical
P0837 Four Wheel Drive (4WD) Switch Performance / Rationality
P0838 Four Wheel Drive (4WD) Switch Circuit Low
P0839 Four Wheel Drive (4WD) Switch Circuit High
P1488 Auxiliary 5 volt supply output is too low
P1492 Ambient/batt temp sensor volts too high
P1493 Ambient/batt temp sensor volts too low
P1596 Speed Control Switch always high
P1597 Speed Control Switch always low
P1652 J1850 Communication Bus
P1687 No Cluster BUS Message or No Messages from the Mechanical Instrument Cluster
P1688 Internal Fuel Injection Pump Controller Failure
P1689 No Communication Between ECM & Injection Pump Module
P1690 Fuel injection pump CKP Sensor Does Not Agree With ECM CKP Sensor
P1691 Fuel Injection Pump Controller Calibration Failure
P1693 Generic fault indicating a fault in the bus or PCM/ECM interface
P1757 Governor pressure is above 3 PSI when 0 PSI is requested
P1762 Governor Press Sensor Offset Volts Too Low or Too High
P1765 Transmission 12 volt supply relay control circuit
P2121 Pedal Position Sensor 1 Performance / Rationality
P2122 Pedal Position Sensor 1 Low
P2123 Pedal Position Sensor 1 High
P2127 Pedal Validation Switch 2 Low
P2128 Pedal Validation Switch 2 High
P2146 Fuel Injector Group 1 Supply Voltage Circuit
P2149 Fuel Injector Group 2 Supply Voltage Circuit
P2266 Water in Fuel Sensor Circuit Low
P2269 Water in Fuel Condition
P2502 Charging System Output Voltage
P2503 Charging System Output Low
P2504 Charging System Output High
P2509 ECM/PCM Power Input Signal Intermittent
P2607 Intake Air Heater Relay 2 Low
P2608 Intake Air Heater Relay 2 High
P2609 Intake Air Heater System Performance
