Code P0336 Crankshaft position sensor??
Discussion in 'VP44 Pump' started by tiger9297, Jul 12, 2014.
  1. tiger9297
    tiger9297 Member
    46
    Oct 8, 2011
    Tupelo, MS
    Ram Year:
    1999
    Engine:
    Cummins 5.9
    I have a 1999 Cummins 24 Valve. Check engine light came on this morning so I read the code with the Edge programmer. Showed P0336 Crankshaft position sensor. Anyone have experience with this? Is this just simply a bad sensor or is this a sign of a more serious problem? Thanks in advance for the help.
  2. Mopar1973Man
    Mopar1973Man Senior Member
    47
    825
    Aug 22, 2011
    New Meadows, Idaho
    Ram Year:
    1996, 2002
    Engine:
    1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
    Yea... It just a wore out sensor. I would go to local part store and pick up a new crank sensor. You have to pull the starter to replace the sensor though. Typically I can knock it out in about 20 minutes.
Share This Page
