Cold weather screwed up my computer?
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
I also tried this and it definitely worked. Truck seems to shift a little better but I will see after it learns.
So what is the entire procedure for this reset?
Is the truck off no key inserted, key in on “OFF,” etc etc etc. I want to try this to see if I can get a little pep back.
TadsRam
TadsRam
Lexington, Ohio
Hemi 5.7 V8
The key is in the ignition on the "OFF" position. Hold down "DOWN" and "LEFT" for a few seconds. While still holding those buttons down, with your other hand turn the key from "OFF" to "AC".. and you should see it do something right away. This seemed to reset recent memory of how I drive or if the extreme cold was screwing with it. I also unconnected the battery for a half an hour to let it fully reset. There is no issue with "pep".. it was just the timing with the automatic shift.
