What tire inflator are you guys using? Having a hard time finding one that has a hose long enough to reach the rear tires. Are there any you guys recommend to mount under the carriage for this?
You are going to want one with a good duty cycle. You can always just buy a longer hose and I would also look into a quick connect relocation kit. I'm out of the office so I can look into it too far but I know we offer a few options for this. We work with ARB, Vair, etc...when I get the chance I'll see what I can come up with. Do you want just a compressor or with a tank as well? Since you are doing this it wouldn't be much more work to do some train horns while you are at itWhat tire inflator are you guys using? Having a hard time finding one that has a hose long enough to reach the rear tires. Are there any you guys recommend to mount under the carriage for this?
I believe this is the one I have. This one has the cigarette plug power vs the standard plug.Which one cause none of them seem to reach
And that'll fill up truck tires?Here is what I use. Since I got it, I quit using all my other compressors. Easy to use, portable. You will need the charger and batteries to go with it.
https://www.homedepot.com/p/Ryobi-18-Volt-ONE-Power-Inflator-Tool-Only-P737/206159256
