the cam provider will tell you the duration for free, when you buy it. one thing you have failed to do for your flat faced 2001 360.
simply using a degree wheel is to set the cam and crank gear, so to install the chain properly. or use the DOT TO DOT method. advanced or ********, "what ever you prefer!"
you can advance a stock 110c-line cam back to 108 and favor the intake stroke. this does produce more with most cams including magnum components. advancing a cam will draw the horse power and torque curve to a lower rpm- before the red line. to retard a cam is just a waste of rpm and my time!
huh what was that?
you need more tools than a degree wheel to determine cam duration!
