mlj1111
- Feb 23, 2017
- 3
- 0
- 2004 Dodge Ram
- 5.7
First Hello. My names is Mike, and I have been around here for awhile reading and learning, but have not had the pleasure of actually registering and posting until now, only as I am about at wits end with my truck. I try to do as much as I can on my own without depending upon others. That being stated,on to my issue.
I bought an 04 Dodge Ram two months ago, Nice truck, runs great, needs a bit of TLC.
Found out on day 2 that battery was draining overnight, forcing me to jump start, and also saw fuse for horn was pulled. Replaced that fuse and found the constant horn issue, pulled fuse until I can figure out what the deal is.
Pulled fuse 51 after reading here and been pulling it daily to keep battery from draining.
I have replaced fuse/relay center, instrument cluster, and horn pad/airbag, as that was free anyways with our recall for airbags.
Drain is still present when radio pulled also.
Drain stops when cluster removed.
Replaced battery.
Alternator is putting out a steady 14.5 volts.
I get the feeling that the horn deal is the culprit, but short of the clock spring, I believe I have replaced everything that I could. I say this as most that have the horn issue also have the battery drain issue present and this seems to be a common issue that is to coincidental to be unrelated .
From my understanding, when your clock spring is bad, you also lose cruise control, and or air bag light flashing. This confuses me as my cruise control is fine as well as my airbag restraint system.
Is it possible that the clock spring can work for other systems, yet cause the horn to blow/drain battery?
I had mentioned that I had replaced the fuse box, that incorporates the integrated power module relays underneath of it. I am curious if there is something between the clock spring and it that is essentially putting power to the horn relay that is in it essentially draining the battery, even though horns fuse unplugged, its still after that fact.
1.25 amp draw.
I have read forums after forum and people describe a lot of the same symptoms that I have.. However, I have yet to see someone post what the actual fix was..
Example... http://www.ramforumz.com/showthread....+battery+drain
or http://dodgeforum.com/forum/3rd-gen...e in with thoughts. Thank you. Mike Johanson
Replaced battery.
1.25 amp draw.
