Correct gas Tank??????? 2016 Outdoorsman 1500
Guzzirider
I bought a leftover 2016 1500 Crewcab Outsdoorsman in early 2017. The build sheet says 32 gal tank but I do not think it has the correct tank in it. When it gets to 1/2 way and I fill it takes 12-13 gals not 16 gals it should and the range seems low, And when it gets low it only takes about 20 gals.
How do I verify which tank is in there?? is a visible part ##
I paid for a 32 gal tank it should have a 32 gal tank
Thanks JS in Bama
kukufixer
Ecodiesel 3.0
If I recall correctly, the Rams have 8% tank capacity left when it says Empty or when it says 0 miles left to empty. If you put in about 12-13 gallons when the gauge reads 1/2 and then add in the additional 2.5 gallons that FCA hid from you, it's about right for a 32 gallon tank.
Or get a 5 gallon can and put in your bed, drive until it runs out, use your 5 gallon can, and go fill up. You will have a definite answer.
noclass
If I remember it actually says 32 gal on the bottom of the tank
G
Guzzirider
I slid under the truck and found this number 22191N which goes not correspond to a Mopar # for the 32 gal tank
I did not see any numbers indicating capacity
looks like a pretty big tank
Neil
How big a tank does an 2012, 1500, 4.7 liter outdoorsman have?
huntergreen
It has been posted that the 32 gallon tank has the same calibration as the 25 gallon tank. Iirc, ramcares says FCA is working on a fix.
