Crank sensor
jcfdtnfirefighter
Johnson City, Tennessee
5.2 Magnum
Any tips on getting to the crank position sensor on my 92 4x4?
I was thinking about removing the front drive shaft and jacking up the motor? ???
bhonshell37
Washington
Where is the crank shaft position sensor located on the motor? My 04 location is lower right side rear
jcfdtnfirefighter
jcfdtnfirefighter
5.2 Magnum
Same place as yours, just too tight down there . I used to have a 95... it wasn't too bad to get to. I think I'm gonna have to jack the Engine up to get enough clearance. ...
crazzywolfie
under the truck
i can already tell you from experience there is no easy way to get at it. you have to take the egr pipe off to get at it which is nearly impossible. i ended up cutting the egr pipe and taking the exhaust manifold off to get at the CPS on my 93. also i think it requires a t25 allen key to remove the bolts. the bolts that held the cps were round allen bolts. the connector is also a pain to get at. i don't think lifting the engine will do anything. if anything removing the motor mounts and lowering the engine might help but still likely won't make the job that much easier.
bhonshell37
Washington
I had no problems getting to my crank sensor. Just crawled under my truck and got'er done
crazzywolfie
under the truck
but an 04 is completely different than a 92. even a 96 and newer ram is different since they did away with the egr on the 96 and newer trucks. the egr pipe is the thing that make the job a real pain in the ass.
