Cruise Control Ain't Cruisin' !?!?
Teligence
Nothing happens when I press the "ON" button - no additional lights at all - the cruise control is completely dead.
The only thing I've done so far is check all fuses - all good.
Any thoughts on what to check next?
Johnnymac2k6
Ohio
2007 Ram 1500
Subscribed. Mine is dead also. Went from randomly shutting off, to completely dead. No dash lights either now.
T
Teligence
cruisin the 'net
Saw a few posts that point to:
- leaking/damaged vacuum hose that goes to the control unit(?)
- bad connection or wiring in the steering wheel harness
- incorrect tire size programmed in the PCM
The first 2 were reports of actual problems that were repaired, but I'm wondering if the 3rd one is just speculation?
Johnnymac2k6
Ohio
2007 Ram 1500
I figured something electronic either in the module or steering wheel. Both seemed invasive to investigate. A new module is $60. But being my dash light doesnt even flicker, I assumed more was at play.
bulrid8
Mine did same thing. Replaced brake switch and it worked for a while, then stopped again. When I installed my tuner and adjusted tire size, my CC has worked perfect ever since.
Sent from my VS985 4G using Tapatalk
Johnnymac2k6
Ohio
2007 Ram 1500
OE tire size here.
no dash light. no activation. this died long before my engine tune.
went from "kicking off" and sometimes working as normal (with dash light), to no dash light, and not working at all.
bulrid8
I would first replace brake switch. $20 at dealer.
bulrid8
Yes that switch. It is a common failure point in the CC circuit.
Johnnymac2k6
Ohio
2007 Ram 1500
ordered the mopar brake light switch...skeptical but for $12 i'll try it. needed plugs and wipers from rock auto anyways.
Johnnymac2k6
Ohio
2007 Ram 1500
you owe me $12
and FYI anyone else replacing the switch, read the instructions first. There is procedure about how to flip a one-time reset switch on the new switch itself. AFTER installing it. IF you hit the toggle before its installed, the switch is RUINED. And if you miss the part about flipping it after installed, your truck will be locked in park.
I almost ended up needing another new switch, and having a truck that was locked in PARK with no way to drive it.
bulrid8
Well of course read the instructions first. Plenty of threads on here that tell you how to replace it.
Johnnymac2k6
Ohio
2007 Ram 1500
Main point being: Cruise control still inop after brake switch, since this thread is about corrective action to failed cruise control.
bulrid8
Well that is one of the common things that go wrong with it. Since it is very hard to test it, it is simpler to replace it and see if that was your issue. There are multiple switches and sensors that operate CC. It is hard to track down.
What is it doing now. Will it light at all when stopped? When moving? Will it light up, but not set? Not hold speed once set?
Johnnymac2k6
Ohio
2007 Ram 1500
Same as previously stated. No dash light and does not function at all.
T
Teligence
Still have a problem?
I've recently ordered the service manuals so I'll have an electrical schematic to troubleshoot with. I'll try and remember to post my results...
Johnnymac2k6
Ohio
2007 Ram 1500
So mine has been working for a week now...and ya know what fixed it? the takata airbag recall being repaired.....? It was dead for 3 years...airbag recall, and boom....works great. I can only assume when they had the steering wheel apart they re-hooked up the buttons/switches and one must have been loose.
Johnnymac2k6
Ohio
2007 Ram 1500
Mine does not work either, what recall???
If you haven't had any recalls done recently,.call your local dealer because you have one on the airbag. Idk if this is actually what "fixed" mine. BUT I bet my switch was loose, and when they put the steering wheel back together it got re connected
snrance
2006 1500 Big Horn
Mine stop working after the ABS wheel speed sensor went bad. The cruise light would come on intermittently and the ABS light never came on.
1Popeye
