Cruise control turning off
Ajwalk2008
Springfield, il
I started noticing today that my cruise control isn't working right. It will turn on while I'm sitting still but as soon as I get around 5mph it will turn off and I am not able to reactivate it after that. I am tuned with diablosport. Has anyone else had this problem?
2005 Dodge Ram 1500 Hemi
Diablosport 91 octane tune
Bullitt5339
St Pauls, NC
I've seen 2 things that are usual culprits with those symptoms:
Speed sensor on trucks with ABS (my 1st guess in this case)
Brake pedal switch
Ajwalk2008
Ajwalk2008
Springfield, il
Light Turns off completely after 5mph and can't get it back on over 5mph
Bullitt5339
St Pauls, NC
Do you know how to do the key trick for codes?
It really sounds like you have a P1501 going on and it just hasn't kicked the CEL yet. The brake switch wouldn't make the light turn completely off, but a speed sensor will.
Ajwalk2008
Ajwalk2008
Springfield, il
yeah, 3 times. It usually takes a couple tries for me to get mine to work.
I thought it was the same I remembered I did it in my dakota. But will it tell me one that hasn't triggered a cel yet?
Bullitt5339
St Pauls, NC
I'm looking at the diagrams, and if I'm reading this right, the front left sensor is the one that can kick off the cruise control without triggering an ABS light.
Ajwalk2008
Ajwalk2008
Springfield, il
Are the sensors in the hub bearing or a separate bolt on?
Ajwalk2008
Ajwalk2008
Springfield, il
I'll let you know in the morning of any codes. Thanks for your help bullitt getting me pointed in a direction
Bullitt5339
St Pauls, NC
No problem. Just FYI for others that may look at this in the future, from my research it seems that this is a Hemi specific problem. For some reason, the other trucks are wired slightly differently which will kick a CEL or ABS light with a speed sensor goes out.
Dodge decided for some reason to kind of leave the left front out of the loop on just the Hemi trucks in 2005.
Ajwalk2008
Ajwalk2008
Springfield, il
I have a pending p1501 code bullitt I'm going to clear it and see if it comes back unless you think otherwise
Bullitt5339
St Pauls, NC
That's what I expected. You can clear it, but it'll likely come back shortly. Left front speed sensor will be your fix.
Ajwalk2008
Ajwalk2008
Springfield, il
Left front as your in the drivers seat or looking at the front
