Cruise Control Wont Engage
Whiteannerdy
2016 Ram 1500 Quad Cab Sport. Under 18,000kms. 5.7 Hemi with CAI
Pressing the cruise control on/off button does nothing. This has been an on/off issue but usually I could quickly correct it while driving and not even pulling over. Up until recently I could hold the "Set -" button for a few seconds and then hit the on/off and it would work again.
Anyone else experience this?
Kapt
3L
Sometimes I have to push mine several times before it will turn on
wsutard1
Woodinville, WA
HEMI 5.7 eTorque
I just got my truck back from the dealer for this issue. The culprit was a connector between the switch and the next computer box it connects to. Took them three days to fix this as they thought it was the switch at first, had to order it, found out it wasnt the issue and then narrowed it down to this connector, and had to order that.
I would recommend taking it to the dealer and telling them this so they can expedite the fix.
Whiteannerdy
Whiteannerdy
Ya. To no avail will it engage. Multiple presses at various speeds or even at complete stop.
Pulled the fuse and not burnt. Likely a software issue I am thinking.
Ferro
If it's under warranty take to the dealer. It's their problem.
Whiteannerdy
Whiteannerdy
If it's under warranty ticket to the dealer. It's their problem.
For sure. That was the plan anyway. All under warranty. Just worth doing your own research before visiting for warranty work so that it's dealt with quickly and without extra unneeded work.
Ramman2014
Nova Scotia
Let us know what they find. Mine won't work at all on my 2014 sport. The 8 speed shift buttons won't work either.
Manchester, CT
Did the dealer every find the cause of the issue? Bringing my truck in Thursday for intermittent cruise control issues as described in this thread. Would love to get t fixed this time, this will be my second trip. First time in they replaced the buttons.
Whiteannerdy
Whiteannerdy
They did repair it. Although they did not replace my switch. The contractors were dirty and reported improper voltage to the computer. Cleaned the contractors, cleared the codes and it has ran since. Although I didn’t get the truck in till early December.
No further issues as of yet.
RamCares
n/a
n/a
Hi Crazydrummer74,
Feel free to send us a PM with your VIN for further assistance during your appointment if needed!
Andrea
Ram Social Care Specialist
Thomas Peters
Hardy, ar
I had this happen in an older ram. It ended up being the brake pedal sensor was sticking, I rarely drive at night it took me 2 years to figure it out. Just fyi
Manchester, CT
The dealer just called me, they traced it to a faulty clock spring in the steering column, which they are replacing under warranty. I’ll be picking the truck up tonight, I hope this is the end of my troubles.
Manchester, CT
Thought everything was fixed as I left the dealer, as soon as I got on the highway the cluster went dead. Back to the dealer Monday :(
SitKneelBend
St. Louis
3.6 Pentastar
I can confirm that holding the gear +,- buttons simultaneously for 5-10 seconds fixes this issue for me.
analogman
I have to put extra umph into pressing the button in my 2015 2500 when it is cold out... Makes no sense...
Skubasteve!
My does this every once and awhile. PUSH that ****** really hard and it'll work for a few months.
Whiteannerdy
Whiteannerdy
Yup. Pushing on it really hard would make it work sometimes. But it was always temperamental. Almost a month and a half now and still working.
MeatCurtains
US
Also check your brake light switch.
Manchester, CT
I want to thank Andrea (Ramcares) for helping me work through my issues with the dealer. The third time around, the dealer from which I purchased my Ram from in December, took one week to diagnose and fix the cruise control issue with my truck. Although it was a major inconvenience the dealer did replace the buttons, clock spring, and finally the wiring harness within the steering column in an attempt to correct the issue. Finally it appears the issue has been corrected. My gut tells me from the poor customer service from the dealer that they wouldn't have given it the attention they did without Ramcares phone call and follow up.
Andrea and her team followed up with the dealer while my truck was getting serviced. They also followed up with me yesterday to make sure everything was to my satisfaction. It was top notch service from the manufacturer, I was very impressed. Thank you!
