Cummins AC compressor?
Stangshcky12
Oshkosh, WI
5.9 Cummins
Looking for some AC help
My girlfriend started her truck and it's started making terrible racket/grinding noise
I've had this weird feeling that the ac compressor is on its last leg for some time now
I climbed underneath and sure enough there are metal shavings on the compressor pulley and it looks as if the pulley might be stripping out
I don't know much about how the clutch on the compressor works but what might be the chances that this is just a bearing/clutch problem and the compressor is still ok (not sure if it even makes a diffrence since i dont think you can get just an ac clutch for these)
infernoredram
South Texas
5.9 Cummins
Is it continuous or only for a sec when you turn it on or change temperature?
I know when I set it a little warmer it'll make this pop/crackle sound the second I set it, but stops and works great
Cthulhu
Calgary, AB
Cummins 5.9
AC clutches are readilly available at your local wrecker...
My clutch died this summer.. AC shop pressed a new one into the old compressor and it works great..
reefguy89
laurel de
sounds like the ac clutch is shot but i dont think you can get new cluchts for it. i think the only way is like cthulhu said via junk yard. might want to check rockauto or factory mopar just to be sure.
Cthulhu
Calgary, AB
Cummins 5.9
Out of morbid curiousity, I checked rock auto.. full compressor is $250ish... F.n.H.l.l.. I paid $400 in Kelowna for the damned clutch..
Stangshcky12
Stangshcky12
Oshkosh, WI
5.9 Cummins
I'll have to look into that
I ordered a non AC serpentine belt to by pass the compressor till I can figure something out
