Some good feedback in this thread. The use 75% of Mfg rated max tow thing.. I assume that was something someone with no idea how to use a WDH & scale figured out. Basically with any half ton truck you can generally tow 75% of its rated capacity even when just blindly dumping the trailer on a regular hitch ball and it will still be ok. Agree with other posters most TT dealers can only get it in the ball park without a loaded truck loaded trailer and no scales. This can leave a lot of stability and safety on the table so to speak. Properly loaded the truck will be safe and stable to tow at its maximum rated towing capacity.
Hmnn from what I have seen and experienced on the practical application of it and or read with respects to the mathamatics & physics of it.. Ideally at minimum replace all the unloaded front steer weight. Best slalom and maximum braking. Airforums had slalom & braking tests using an Airstream on this. I believe it was Andy at Can Am RV dealership that either did or posted these.
Often taking a rig from "white knuckle" to stable also from out of spec to in spec or in warranty or "legal" as some would say is only a matter of proper set up.
Down & dirty. 1. Weigh the unloaded truck for steer, drive, & total weight. 2. Weigh the loaded truck & wet TT.
3. Adjust WDH, load in the truck, and load in the TT, then re-weigh until you have at minimum replaced the unloaded steer weight and have drive axle weight down to max axle rating or below. Subtract unloaded truck weight from the loaded truck weight for accurate tongue weight. (This is because when using a WDH tongue weight is no longer static weight but rather dynamic weight) That number divided into the gross trailer weight will be your tongue weight percentage. This needs to be between 10 & 15 percent. Now you have a stable safe tow with best emergency swerve around for accident avoidance and maximum stopping power. You should still review your scale slips for CVW, GVW, and tongue weight to receiver rating. If you no longer have stock original tires check their weight rating as well.
Note by adjusting hitch & load you can lower your TW and truck GVW. Sometimes with heavier trailers for warranty & such people want the TW down to where they are below the trucks GVWR. Other times the priority is a little more TW for maximum stability. Physics wise on a bumper pull for lack of proper term its preferable to have more weight on the TV axles than on the TT axles so the tail can't wag the dog as they say.
Here is a free CAT scale locator app for your phone. It also has GPS on it for guided directions.
https://catscale.com/cat-scale-apps/
