im looking into buying a 86 d250 for 300 bucks. its got a good running 318 it needs brake work (i think just lines) and minor odds and ends. the body is about 85% rust free. the frame has a little scaling in the rear. id like to put a 4-6 suspension lift in it. im low in the cash department so id like to do a lift out of junkyard parts. i was thinking 4wd 1 ton springs in the rear and maybe a shackle flip or blocks. im not sure or used to the front suspesion. i need some cheap ideas for the front and could use some opions/ideas about the rear
